Parametric Ugrinsky Blades
ive made up some Ugrinsky blades, alterable by height, diameter, thickness etc. was kinda tricky, I ended up making a 10 degree offset baseline, drawing the sketch on that, then i can set the rotation to 0 and its not constrained to horizontal. i used 6 planes total and adjusted the original rotation as a ratio of the overall twist variable. the planes also use a ratio of total height variable as offsets from nearest lower plane. all in all a good learning experience as a newbie. hopefully the blade part studio is fully constrained now
please go easy on me!&
Hello, Alex, did you tester real model? How much power does ir generate? How meny coil windings did you use for each coil?
