What is the technique that replaces trimming surfaces??
dave_franchino
dave_franchino Member Posts: 78 ✭✭
Hey Folks,
I am used to a number of cad systems where the modeling strategy for complex surfaces involved "over-build" and trim back - basically sweeping or lofting large blankets of surfaces and then trimming them to achieve your desired shape (before thickening). I'm still pretty new to Onshape but there does not appear to be a surface trim command. Am I missing it? Or is there a different technique to replace this one?  Thanks!
Dave
    There is a mutual trim feature, but if you want to trim an individual surface, use the Split / Face feature and then Delete face to remove the portion you don't want to keep.
