Moving to the origin
rraffaell73rraffaell73 Member Posts: 13
When the imported file is in STL format, for example, there is no option to use the Transform command in the tools... How do I move this imported file to the origin, if it is far from there? Thanks!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    You can use Transform on a mesh.
  • rraffaell73rraffaell73 Member Posts: 13
    Yes! After all, I managed to find a way to move the file to the origin, using the transform command... Thank you!
