Same Variable Name!
Bahrami
Bahrami Member Posts: 1 EDU
Hi
I just start learning Onshape from learning center and special thanks to this amazing team.
I have a question about variables.
In the last exercise we should put the same name for variables, Can someone explain me that reason?
Cheers
Alireza.
  • romeograham
    romeograham Member, csevp Posts: 782 PRO
    edited January 2024
    Pay special attention to the Pattern - where "Features" are patterned (or maybe that exercise uses a Sketch Pattern). You'll see how the variable #Slots is used in the pattern.
    Variables are solved in the Feature List in the order they appear - so #Slots can have different values depending on where it appears in the list.  I've mostly seen this used in Patterns.
    However, you can also use it to Override a variable that may have been imported / derived into your Part Studio - you can use the same name but a different value for that variable, and Onshape will use the last value assigned.
    Good luck, and Welcome to Onshape!
