Circular Pattern of a Feature
kermit_achterman
Member Posts: 1 ✭
I have a basic solid cylinder with one axial hole which is not on the cylinder center line. I am unable to create a circular pattern on the hole about the cylinder center line. The box is asking for a part or a face to pattern but will not accept a hole feature.
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
We currently don't have feature pattern. In this case, I would try to use a face pattern and select all of the faces of the hole.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5 -
3dcad
Member, OS Professional, Mentor Posts: 2,482 PRO
Meaning that you need to select the cylinder AND the bottom (if the hole is not going through).jakeramsley said:We currently don't have feature pattern. In this case, I would try to use a face pattern and select all of the faces of the hole.
As face pattern is not very robust solution against future edits to the part I would suggest using sketch pattern instead and extrude all sketch entities with one extrude command.//rami5 -
thomas_kozak
Member Posts: 38 ✭✭
Bear in mind that if you want to adjust the number of holes with a variable, you currently must use the face pattern option as sketch patterns won't accept a variable (I've been told this will be fixed).5
If there was robust feature pattern I would use that. My suggestion is just my experience with Onshape.
The problem is that if you edit something in history that affects to faces in the pattern it will break.
I hope we would see feature pattern/mirror in next updates.
