Locking a line or objects inference direction
jack_erhartjack_erhart Member Posts: 140 ✭✭
Is there a way to lock a lines inference direction when drawing? A shortcut key for this would be great. Same thing when moving an object or part would be helpful. Thank you for your help.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,950 image
    It will draw horizontal and vertical naturally, but if you want something parallel, you can "wake up" the contraint by touching the parallel line momentarily.
