Reorder Cut List
James_P_Miller
James_P_Miller Member, csevp Posts: 42 PRO
Maybe I'm missing the obvious, but is there a way to reorder a cut list without having to reselect the items in the correct order? I just found an item that wasn't included and I'd like to add it. We typically list our tube by cut length, longest to shortest.
Thanks!
James P. Miller
Mechanical Design | Custom Automation | Onshape CAD
https://millerdesignservices.net
    Sorry, but there is no way to do this right now.
  • caq1
    caq1 Member Posts: 5 PRO
    Does anyone know a work around for this. Really frustrating, I need to be able to sort longest to shortest and then by material.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,959 PRO
    edited May 2024
    There is a work around @caq1, but it would involve developing your own modified version of the Cutlist feature so that it re-orderes the cutlist entries. You could do it yourself, or have someone else do it for you.
    Let me know if your interested in having someone do it for you, I can set up a discovery call for you with CADSharp.
  • jnewth_onshape
    jnewth_onshape Member, Onshape Employees Posts: 89 image
    @JPM
    This is a good idea!
    Please file the feature request via the "Contact Support" button:
    Or you can post it here, in the feature request category, so other people can vote on it as well: https://forum.onshape.com/categories/improvement-voting
  • James_P_Miller
    Update:
    I decided to make a custom tool for this myself and it worked out better than I had hoped.
    Cut List Pro is available here https://www.millerdesignservices.net/feature-scripts
    James P. Miller
