Using contours for extrusions
chris_redingerchris_redinger Member Posts: 6
I'm struggling to use contours for my extrusion profile. Onshape requires selecting faces only for extrusion.
You can select contours BEFORE extruding by using the janky selection tool, but this tool DOES NOT WORK for filling in an option box in the extrude feature.
    Course it does.
  • _anton_anton Member, Onshape Employees Posts: 525 image
    Surface extrude works fine as far as I can tell. Are you trying to select construction geometry or non-sketch edges?
