Can Command Aliases Be Used?
I use OnShape Free for personal projects and Inventor at work. I have Inventor configured so I can access nearly everything from the keyboard with command aliases. I have not found this functionality in OnShape and it’s painfully slow to use as a result.
In Inventor, I type the first few letters of the command then hit enter when I see it narrow down to the correct one. I even access document properties and settings this way. Any item in the ribbon in Inventor can be accessed with an alias. My mouse remains conveniently close to the model and never needs to travel to the ribbon.
Using OnShape is a bit torturous without command aliases. I have not been able to find this feature. I am 10X slower in OnShape purely because of this reason, no exaggeration. Is this feature available in higher plans? Are there any extensions that add this?
My doctrine is that the mouse should be used only when necessary. 10 fingers are always faster than 1 hand.
No plans to add this.Senior Director, Technical Services, EMEA0
You can also start typing to find features
Alt-C (Option-C) opens the search dialog, and then start typing. "Mut..." will find Mutual Trim, for instance (and all the other matching commands). This works for default toolset features as well as your custom features you have in your list. I find it's often faster than poking through menus for commands.
The search is pretty smart, too - if I misspell a command (type "file" instead of "fille..." for Fillet) it will still return the correct item very quickly.
NeilCooke said:No plans to add this.
Sad, it's a well-established standard that keyboard shortcuts are faster than using just the mouse. That's been true for decades. I am not surprised that basic ergonomics are ignored considering that OnShape did not have proper model orbiting until recently (constrained orbit).
If Onshape had started with only a constrained orbit view mode, I would have been much less likely to start to use it. It really depends on what you're used to and the sort of modeling that you do. To each, his own.
2 -
Keyboard shortcuts are much different than command line input (like autocad) which requires you to take your hand off the mouse (unless you speed type with one finger).1
@colin_starker933 The s-menu might be a good tool for you. You hit 's' in part studios, drawings, sketches, or assemblies, and a toolbar pops up very close to the mouse cursor. This can be configured, under My account > Preferences > Shortcut toolbars. You can also add custom features to it, making it a very flexible interface.
I came back to Onshape after working with Ansys for a while. Still no plans to add aliases for all commands?
Many things can get custom keyboard shortcuts these days.
https://cad.onshape.com/help/Content/Home/keyboard_shortcuts_and_hotkeys.htm
Many things, but not everything, and there is a huge difference between those regarding speed and RSI prevention. Ideally, every UI action and tool should be reachable from an alias, which the fastest, or a command line or search box at minimum. The mouse should be reserved for manipulation of the model.
Solidworks is a good example of this implementation. A non-CAD example is Sioyek PDF reader with nearly no GUI at all (because competent users outgrow it) and everything is reached with a command line. Of course, in both examples, shortcuts can be assigned to anything too.0
