Problem with sweeping a profile
darren_christensen
Member Posts: 4 ✭
Spent sometime looking through all the sweep threads but haven't found an answer. Cannot get the last segment to generate without an error. The intersection of the segments doesn't look much different than others but it won't generate. Any thoughts or help would be great!
https://cad.onshape.com/documents/8032dec72629bc83998673ce/w/e1d2eaaa527fdd98b3aec390/e/8089bfa774614949e28d2651
OptionsS1mon Member Posts: 2,406 PROI don't understand why this should make a difference, but I replaced the arc that is the offending segment of the sweep path with a spline, and it works fine.0
