Document won't update, also how to update all documents at once?
david_brophydavid_brophy Member Posts: 53 ✭✭
I have lots of documents, and each time I open them I'm faced with update process where I have to close the document:
Is there a way to force all my documents to update at once? One of them seems to have got stuck on the old version (the "Decal" command is missing)... It doesn't prompt me when I open it... Any way to get it to update? It's this one:
https://cad.onshape.com/documents/bac5f4b89cd29e728d76720e/w/9e8e7481aa82127a53bd524e/e/a5e383d14edf31349a54ed55?renderMode=0&uiState=6604b3dcf10d7d54a148f09d
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    Simply opening a document should not require it to be upgraded, only restoring or merging triggers this. The document you listed was copied from another document which was previously not upgraded itself maybe beacuse it hasn't been touched for a while. One quick way to force an upgrade is to trash/restore the doc.
  • david_brophydavid_brophy Member Posts: 53 ✭✭
    Yes, I think I got into this mess by clicking "Later" instead of "Now" in the feature library upgrade box, *then* duplicating the document with the "Copy workspace" command. The new document was then stuck on the old workspace and didn't ever prompt me to upgrade. Trashing / restoring worked great.
    It would be great to have an option to upgrade all documents at once... My project has hundreds of documents and updating them individually as they're opened is a bit of a pain...
    Alternatively a way to list all documents that need upgrading so I can go through and do them all at once...
    This dialog is so frustrating:
    Yeah I just updated a document, waited a few seconds and re-opened it... but I guess I re-opened it before it had finished updating, so it's not updated, and it's rescheduled it to be upgraded in 20 minutes time... So I'm having to wait 20 minutes or trash/restore. This is happening several times a day and it's infuriating 😂
    OK actually delete / restore doesn't trigger the document to be update if it's scheduled. I guess I'm waiting 20 minutes until I can continue work 🤦‍♂️
    All docs get upgraded every 3 weeks after a software update (with some exceptions), so not sure what has happened to all yours. I tried to look through some of my old docs to test the trash/restore theory and I couldn't find any that were out of date!
    Hmmm interesting... I haven't touched this project since June last year, and only just started work on it again, so perhaps that's why...
    Again I've had a few months without using Onshape, and when I come back, I get the dreaded "[Document] has not been updated to the latest version of the feature library" error on every document. I'm literally sitting here waiting for minutes when I open each new document.
    Is there still no way to trigger Onshape to upgrade all documents at once? This is really interrupting my workflow 🤦‍♂️
