surface modeling help needed
creation_ink
creation_ink Member Posts: 6 ✭
Hi, I'm fairly new to onshape, but I have taught myself how to do 3d modeling on solidworks for some years. I'm working on a project that requires complex surfaces. I want to design a parametric slides/flip-flops model. I made an earlier version in solidworks, but i cant apply the same methods in onshape. I have made a detailed wire frame of the model, but I'm unable to create the surfaces out of it. Any advise, technique, best practices is appreciated
    Why can’t you apply the same methods you used in SolidWorks? Modelling in both systems is almost identical.
  • creation_ink
    Hi Neil, thnx for your reply. In SolidWorks I can use multiple guidelines from 1 sketch (select open loop). In OnShape, it doesnt seem like it selects the whole open loop, only a segment of it. I want to create a boundary surface or loft surface between 2 closed projected curves/loops connected with guidelines. However I cant complete the loop as it eventually gives me an error the more guide lines I add. Maybe if I could show you the model it would be easier to spot my mistakes, but I'm not sure how.
    Just share the URL, but it sounds like a selection issue. Once you've selected one item, expand the selection in the dialog and add more entities to it.
