In context edits don't update when configuration changes
in General
I have a drawer front that can be various widths. Latches on either side need a complex recess routed into the wood. I've positioned the latches in the assembly, then used in-context edit to cut the recess. This works great, until I change the width of the drawer-front by changing the configuration variable. The recesses are now in the wrong place. I've made a simplified demo:
https://cad.onshape.com/documents/6b3201709c47974d980be713/w/ea2c99aee6826c0087e36cbc/e/785d95cc34fdef7dcd38a873
1
https://cad.onshape.com/documents/aa96484937e4b35f1a7bcc1a/w/6208b1d9e94f9a42f046f598/e/4613c58510384a1dfb09964e?configuration=default&renderMode=0&uiState=660f01f6c6a1e66a0e340230
https://cad.onshape.com/help/Content/assembly_configurations.htm?tocpath=Assemblies|_____6
https://cad.onshape.com/documents/16dd5c53137283ef24438b7c/w/36da66510257517b8f92b61b/e/338da39250746a962d89c618?renderMode=0&uiState=6611f60da802425600ccee47
The cut-out is defined by the hidden "Recess" part, which I use with the boolean feature to cut out material from the shelf.
I'm not sure how assembly configurations will help things?
You already did the hard part with creating the part to boolean from the shelf. Now you just need to derive that part into your shelf part and transform it (by mate connector) to be offset the correct distance from the end. Or use the super derive to derive and locate in one step...
Like this:
https://cad.onshape.com/documents/b9a1b78d24da28b71b9dd10b/w/2b4e1bc0b6f818e30d16ffd7/e/c027b7fd4a12c00a59e14e88?configuration=length=0.129+meter&renderMode=0&tangentEdgeStyle=1&uiState=6612cccb34b161494406371e
In context definitely not the best option in this case.
