Variable input in linear pattern switches to number
At first I thought it was just my mistake, but I've had this happen about seven times. When I input the spacing on a linear pattern I write it as an equation (2*[a+b]). Works great, until I change the variables a bit down the line and the linear pattern has a number for the spacing rather than the function. I'm having trouble reproducing it precisely, but I can show a more precise example if needed.
Thanks!
