Get a Vector from an Edge
Alex_Pitt
Member Posts: 78 PRO
Is there a way to convert an edge (query) to a vector?
I've asked Chat GPT but it just seems to make stuff up...
"Hi, Chat GPT here,
In Onshape FeatureScript, you can convert an edge to a vector using the
"Hi, Chat GPT here,
opEdgeToVector function. This function takes an edge as input and returns a vector representing the direction of the edge.Here's a simple example demonstrating how to use opEdgeToVector:
javascriptCopy codeimport(path : "onshape/std/geometry.fs", version : "252.0");
// Define a simple edge
const edge = edge(context, {
start: vector(0, 0, 0),
end: vector(1, 1, 1)
// Convert the edge to a vector
const edgeVector = opEdgeToVector(edge);
// Print the result
println("Edge vector: ", edgeVector);
This script creates a simple edge from the point (0, 0, 0) to the point (1, 1, 1), then converts this edge to a vector using opEdgeToVector, and finally prints the resulting vector..."
You got it.Senior Director, Technical Services, EMEA0
You’ll need to look at the help/tutorials a bit to get the fundamentals. ChatGPT clearly does not understand the difference between queries and evaluation, amongst other hallucinations it’s having.Evaluate is what you need to do to a query that refers to an entity like an edge.Check out evEdgeTangentLine in the docs….1
@GregBrown thanks. Haha yes! ChatGTP can be very "creative"!
I'm not up to speed enough for the help to mean much... evEdgeTangentLine(context, map) returns line. If this will somehow return a vector from an edge query I will investigate further.
Re tutorials, I did the Fundamentals course a few years ago which is very good but I'll need to revisit. I'll keep plugging away. I'm sure it will twig in time.0 -
This could be helpful...
var myLine is Line = evEdgeTangentLine(context, { "edge" : definition.edge1, "parameter" : 0.5 }); var myPoint is Vector = myLine.origin + myLine.direction * 2.5 * inch; debug(context, myLine); debug(context, myPoint);0 -
When I tweak the above to this...
var myLine is Line = evEdgeTangentLine(context, {"edge" : edge1,"parameter" : 0});var myPoint is Vector = myLine.origin + myLine.direction *0*mm;debug(context, myLine);debug(context, myPoint);
The debug looks like this.
debug: Line direction (-0, -0, -1)origin (0.1 meter, 0meter, 0.3 meter) //that's the top point of my selected edgedebug: Vector (0.1meter, 0 meter, 0.3 meter) //same point as abovedebug: Vector (0.1 meter, 0 meter, 0.3 meter)Result: Regeneration complete
I can now get the length of my edge. (0.3m) by multiplying the respective components of the Line direction unit vector (-0, -0, -1) and the myLine vector (0.1m,0m,0.3m).
Seems a very convoluted way to do it though.0 -
Is it the length you are looking for? evLength?
Senior Director, Technical Services, EMEA0 -
@NeilCooke Thanks, evLength is great as I do need the length. I also need the unit vector (line direction) of my edge. I plan to multiply the two, to get a vector to feed into opTransform. (All part of my cunning plan to move a part along an edge).
I'm unsure how to get the unit vector so I'll have a look through the help. Maybe one of the evaluate functions...0 -
evEdgeTangentLine returns a Line object where the “direction” is a unit vector.Senior Director, Technical Services, EMEA0
@NeilCooke thanks. Yes I saw that.debug: Line direction (-0, -0, -1)origin (0.1 meter, 0meter, 0.3 meter)
A "Line" is a special kind of "map" is that right? Direction + Point. Infinite length.
Unsure how to isolate the "direction" component of that "Line".
Looking to the help..."...Map elements are accessed or changed using the map key. If the map key is a string that is a valid identifier, dot syntax may be used.
var val = map2.a; // v is 1 val = map2["a"]; // v is 1 map2.a = 0; // map2 is now { "a" : 0 } map2.b = 1; // map2 is now { "a" : 0, "b" : 1 }So maybe..
myLine.direction ?0 -
It works!
Thanks Neil & Greg....var myEdgeLength = evLength(context, { "entities" : myEdge });var myLine is Line = evEdgeTangentLine(context, {"edge" : myEdge, "parameter" : 0 });var myVector is Vector = myLine.direction*myEdgeLength;opTransform(context, id + 0 + "transform1", {"bodies" : myBody, "transform" : transform(myVector) });
});0
