How to search for a Document Name, when only a few middle characters are known.
eldon_brown
eldon_brown Member Posts: 52 ✭✭
How can I use a "wild card" for Document File Name search that contains a sequence of characters in the middle of the Document Name?
For example:  *Connector*
  • eldon_brown
    edited April 2024 Answer ✓
    glen_dewsbury
    ***** Try "*mets*" as your search, I do not think it will work! *****
    CORRECTION: I must not have be waiting long enough, It now WORKS for me also as "*flag*" !
    (I must have too many files or a slow network connection)
    Thanks, this answers the Question, Thanks ALL
    I can now go back to my "CamelCase" and "Snake_Case" file names as desired.
    Thanks.
    S1mon Member Posts: 4,616 PRO
    What I have found is that searching for "foo" will find "blah-foo-baz" and "blah Foo baz" but not "bing_foo_bar" nor "BingFooBar". Searching for "*foo*" will find all of them, but takes longer.
    Underscores or camel case don't work as well for Onshape search, especially for people that forget to use the asterisks.
    That works for me?
  • eldon_brown
    NeilCooke;
    If it works for you, I must be doing something wrong.
    It does work if the search word starts with a "space" (or nothing). For example, while looking for a Document like, "GoFlag_R01", searching for "flag" does not work for me. It does work if the Document name is "Go Flag_R01".
    To be compatible with our downstream process as exported files, I use "CamelCase" or "Snake_Case" for file names for all Documents. I avoid "spaces" within names as most of our downstream processes (CNC, 3D Printing, Plasm, etc) and file storage run on Linux systems and therefore file names with spaces are a pain to manage.
    A Onshape File Name Search with "wild card characters" would solve the problem and would be great.
    BTW, the file system and lack of a good search function and a way to view a multi-level directory structure is one of the main reasons that we are moving away from Fusion 360.  I think I have over 3000 project files within a multi-level folder structure in my paid F360 subscription service and it is a terrible process (it really sucks) to try to search for very old projects.
  • glen_dewsbury
    edited April 2024
    Eldon. I just tried the same thing and it worked. Are you sure that you have a document that includes that name or maybe a misspelling in the document name?
  • eldon_brown
    glen_dewsbury
    Thanks.
