Is there any way to fetch all parameters can be used to create a feature?
liang_dai
liang_dai Member Posts: 5 ✭
Is there any way to fetch all parameters which can be used to create a feature such as sketch, extrude, etc. Using Get the Feature List end point won't list all parameters and I can find any document to learn those params which makes me confused when I using feature-creating rest api to create my own feature
    NeilCooke Moderator, Onshape Employees Posts: 6,113 image
    See the FeatureScript definitions https://cad.onshape.com/FsDoc/library.html
  • liang_dai
    Thank you for the answer, Neil. We can't create featrues using feature studio which internally uses feature script codes because such feature will hide all it's internal heriachy being shown on Part studio which we will use to run our automation script. So we can only use rest api to create all features we need. But using rest api to create features always need we input a 'btType', so what we really need is a document to describe all 'btTypes' and how we use it.
    OK - does this page not give you everything you need? https://onshape-public.github.io/docs/api-adv/featureaccess/
