evOwnerSketchPlane can't figure out a sketch's plane
gregory_tu
Member Posts: 6 EDU
Doc Link: https://cad.onshape.com/documents/e746e5a1af6ab69016ffd94f/w/081cbbc49abd4344596a9144/e/a9ac389edf3d50f310bc8113
(At bottom of featurescript is where I've been trying to get it to work)
I made a ridged tab feature that could add a little tab connection for 3dp parts, but when I try to have evOwnerSketchPlane evaluate a sketch's plane that was placed on an inside edge, on the inside of a cylindrical face, instead of on the outside of a cylindrical pin head, it says it cannot resolve (@evOwnerSketchPlane: CANNOT_RESOLVE_PLANE). This situation should be the same except for the faces around the edge, but the edge itself should still be perfectly circular, and planar, so I don't know why it now can't figure it out as I am still directly referencing what created the sketch.
You were querying the sketch outside the loop, so moved it inside and changed your id hierarchy:
for (i = 0; i < size(pinHeadEdge.subqueries); i += 1) { var sketchPlane = evPlanarEdge(context, { "edge" : qNthElement(pinHeadEdge, i) }); var slitSketch = newSketchOnPlane(context, id + i + "slitSketch12", { "sketchPlane" : sketchPlane }); // Create new sketch on each pin edge plane var circA = measureDiameter(context, { "entity" : qNthElement(pinHeadEdge, i) }) / meter / 2; // Measure pin head diameter var tabWidth = (definition.slitDepth / meter / definition.tabFlexMult) / (definition.ridgeSize / meter / 0.000396875); var slitWidth = max(definition.ridgeSize * 2 / meter, circA - tabWidth * 2); skRectangle(slitSketch, "slitRectangle", { "firstCorner" : vector(-circA - definition.ridgeSize / meter, slitWidth) * meter, "secondCorner" : vector(0, -slitWidth) * meter }); skSolve(slitSketch); // Solve sketch opExtrude(context, id + i + "extrude12", { "entities" : qSketchRegion(id + i + "slitSketch12"), "direction" : sketchPlane.normal * -1, "endBound" : BoundingType.BLIND, "endDepth" : definition.slitDepth, }); }
Senior Director, Technical Services, EMEA0
