Loft fails when guide curve is too severe
steven_schaefer
Member Posts: 4 ✭
This is my part. The highlighted curve is the curve in question here.
This curve is being used as a guide for a loft. It is working fine in the screenshot above, but I need the curve to be "curvier." See next screenshot:
If I adjust the curve to be what I want, the loft fails. I can understand that this is a harder shape for the loft to generate, but I know that this geometry is "possible," it's just that OS doesn't know what I'm asking for. The error in the loft says "Current selections would create a self-intersecting body."
So what methods would I use to create my desired geometry? Do I have to create some more profiles between the start and end profile? I would rather avoid that if I can, but I will if I must. But I'm not certain if that would even help me here?
Link to project: https://cad.onshape.com/documents/26f9e1b6fa91e02ab1d6f488/w/07fa643a9692002a9957fee1/e/4bf4c19c6ca45c63819ce17f
martin_kopplow
Member Posts: 1,077 PRO
It could be that the inner and outer surface of the resulting shell self intersect or with an end face. I'd build the faces one by one to get more control over it. Maybe the outer surface could need an additional guide curve.
