A weird Fill Pattern problem
jim_sung
jim_sung Member Posts: 3 ✭
I'm an experienced software engineer, but I'm new to FeatureScript, Onshape, Onshape standard library, etc.  I made a copy of Fill Pattern so that I can debug it and perhaps add partial patterns to it down the road.
For a simple part, Fill Pattern works just fine.
Here is the link to my document: https://cad.onshape.com/documents/ef4f3114a26fd805747c5959/w/5d416ce85b552a6afb314618/e/69386092e3b94f9253623c12.
So, I get "Array index -1 out of bounds", but I accidentally discovered that if I have a stupid sketch that uses the same target face as the sketch plane, then Fill Pattern works as expected.  The problem seems to stem from startTracking(), and if I comment it out, Fill Pattern works as expected too.
So, what is the intent of startTracking()?
    NeilCooke Moderator, Onshape Employees Posts: 6,114 image
    Hi Jim, it's failing because the area to fill is before the feature to pattern. Something I hadn't tested and I can't remember for the life of me why I added the whole section starting:
    if (isQueryEmpty(context, qSketchFilter(definition.target, SketchObject.NO)))
    and you're right if you comment out the whole section it works. I will review and update - thanks for the free QA.
