how to use plugins?
I want to try the Keyshot cloud plugin but I don't know how to use plugins with Onshape. I don't see it as an option anywhere.
  • cadmandocadmando Member Posts: 68 ✭✭
    Have you accessed and downloaded the Keyshot App, if so this is a desktop app and will be stored as an App on your desktop, when you run this App you wll find a Button or a drop-down menu which will allow you to access Onshape and all your Documents. Some of the App's are Cloud based and Access to these are through Onshape, Under the ' + ' sign is an option to Add an Application, this is only available if you have downloaded any Cloud based App's
    Do you have valid Keyshot 6 license? Live link only works with the newest version..
    I'm not sure (as I have Keyshot 5) but I think it will create a menu inside Keyshot which will be able to connect into Onshape models.
    //rami
