Connect Extrude to Spline Revolve (with a Loft)
tilman_liero
Member Posts: 2 ✭✭
Hi,
probably a newbie question but I'm stuck and the search did not help either...
I have a kind of bowl I created from a spline that I revolved and thinckened afterwards. In this bowl there is a vertical platform that was created by simply drawing a rectangle at the bottom and extruding it.
Thanks for any help! The document can be found at
https://cad.onshape.com/documents/b7d6d4ac153f4002984b8831/w/634faeec6ce042cd85aaaaa3/e/d2e9440b14894c32aad39a99
Hi Tilman - you can use the delete face feature on the thin vertical sides of the wall. You could have probably also drawn the wall vertically on the right plane then extruded it in both directions "up to part".
Senior Director, Technical Services, EMEA5
Senior Director, Technical Services, EMEA5 -
Thanks a lot, guys! Actually, both answers are helping me a lot. I did not know about the "up to part" option before - that is pretty staight forward. The way using Boolean feature is also pretty clever and the technique is something that'll be of use for me.0
I must admit I hadn't used the delete face feature before, and this example shows a very useful situation for it. However, somehow it still feels like it's not proper modelling, though. :-)
@shanshan - indeed! There are always several ways to model something. For example, you could have created your extrusion using Add (so it's all one part) and then used delete face to remove the bits sticking out of the sides!
Senior Director, Technical Services, EMEA0
