How to have a Sketch as a parameter
nir_naron
Member Posts: 26 EDU
I’m not sure I’m getting the terminology correctly, but when I’m saying parameter I’m referring to the light-blue input boxes that are in the feature-menu that pops up when creating a new feature.
Say, in a Part Studio, I creat a new Extrude feature. I can either manually select entities to extrude (with my cursor), or I can click a sketch in the feature-tree, and the sketch’s faces get extruded.
How can I set up a new parameter, in my own feature (using FeatureScript), to accept an entire sketch?
Hey @nir_naron, welcome to FeatureScript! To allow for the faces of an entire sketch to be selected, you can use this as a parameter:annotation { "Name" : "Entities", "Filter" : EntityType.FACE }
definition.entities is Query;
▚▞▚▞▚▞▚▞▚0 -
MichaelPascoe Thanks! Yeah it turns out I only needed to remove the MaxNumberOfPicks filter1
