Roughly how would you create this Part?
john_smith077
Member Posts: 175 ✭✭✭
Hello
I am new here. I am trying to create a solid model to be 3D printed.
Roughly what steps would you take to create a 3D solid model that looks approximately like this:
I am trying to work 'parametrically' (is that a word?!).
I am thinking the best thing would be to use the Sweep tool, rather than the Fillet tool.
But would I be best to:
a) Work with surfaces first and then (somehow) close the surfaces so as to create a solid. OR
b) Create a collection of solids which I then (somehow) fuse together.
I am also extremely unclear how to fill in that flat square-ish middle bit
Many thanks
J
Many thanks
J
Yes, that would be my first impression for that type of parametric model.
WAIT, no need for sweep, just extrude + fillet//rami1
I would make it all square then add fillets
gideon waldner3 -
for b - you can boolean parts together if they touch each other. When you create new extrude, there is options new, add, remove. Use add to include body in existing part, merge scope will define the part where new body is added.//rami0
@3dcas - would you recommend a sweep using a square profile followed by fillets?0
