Assembly Planes - Where are they?
ryan_grice
ryan_grice Member Posts: 2 ✭
It appears that planes in assemblies are not an option. I've searched this forum for answers and found discussions from several years ago, but surely there's an update to this fundamental feature, no?
    S1mon Member Posts: 4,618 PRO
    No update. It's one of the strangest product decisions that I had to get used to in Onshape. I usually create an assembly mate connector at the origin to make it easier to mate parts or sub-assemblies. If it's helpful, it's not hard for this "origin" mate connector to have its Z axis pointing in the direction that makes the most sense for your subsequent mates.
    The most challenging issue of not having assembly planes is taking cross sections when there isn't a good reference to start from. It's even worse on mobile.
  • martin_kopplow
    martin_kopplow Member Posts: 1,644 PRO
    When designing furniture style objects, or other things that are to be set up on some kind of floor, I usually work around the missing 'ground plane' by adding a floor plan model which may be nothing but a sketch.
  • shawnrw
    shawnrw Member Posts: 50 PRO
    I couldn't agree more on the mobile experience regarding assembly planes & cross sections.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,936 PRO
    Not sure if helps with mobile (if it's been implemented or not) but the new "mate connector at origin" of part should help provide at leas some point to start a section.
    On top of adding a mate connector(s) at the origin, otherwise adding a couple explicit mate connectors to your part can usually solve the problem, or inserting a layout sketch in the assembly is also a good option for more complex cases.
    The reason there are no assembly planes is because Onshape does not use planes to mate parts together. It would promote the old "3 planar mate technique" rather than a single mate/connector.
  • glen_dewsbury
    I find it interesting to see this discussion still going around. When starting with OS I initially found myself wanting assembly planes because of the previous tools I'd worked with. However, I haven't missed it at all once I spent some getting used to OS methods and that didn't take long. The biggest problem was to align non uniform shapes but once I got used to the multipart studio and inserting in place the problem really didn't exist. Maybe some more instruction in the basics to handle conversion for those that have used other tools?
  • romeograham
    romeograham Member, csevp Posts: 782 PRO
    In any new assembly I immediately place 3 Mate Connectors at the origin, with their Z-axes pointing along the X, Y, Z axis of the view cube. I even name them "X", "Y", "Z"! You can "lock" the Z-axis to different directions using the Shift key as you hover over the origin during Mate Connector creation.
    This way I have the usual planes for section views (select the MC you want before you invoke the section). Mate Connectors behave like Coordinate systems, axes, and (1 xy) planes, all in one element.
    For most default component positional mates, I make sure to select the Z mate connector from the instance list - since it's tough to pick from the display area. These mate connectors are also fantastic for any patterns that you need to create in the assembly - the Z-axis defines the "direction".
    This is a good work around, but it seems like something should be built in.
    There are no part studio or assembly templates, and no assembly feature scripts, so there's no quicker way to add those 3 MCs. You could duplicate a tab, and move it to another document, but that seems more awkward.
  • romeograham
    Yep - it's a total workaround. At least it can be quick if you remember to:
    • hide the first MC you create (so you can select the origin for the next one!)...and
    • remember to use Shift to lock to the axis you want,
    • Shift+N to name each one as you create them, and if you
    • remember to use Shift+Enter to save each one and keep the dialog open to make the next MC (see - this has already taken longer to type than to add them).
    For me, the main hassle is the lost time when I forget to add these MCs at the beginning and use other less robust references instead...until I remember that I like the 3 MC workflow.
    If you are as obsessive as I am, you'll also want save some time by creating the MCs in XYZ order, so that they are in order in the mate features list (or you'll just have to reorder them afterwards).
  • JABR
    JABR Member Posts: 13 PRO
    I fully agree that these are workarounds and there should be a built in solution.
    I'd really like to see a mate connector which behaves as a full coordinate system (3 selectable axis and planes), so we don't have to add 3 of them every time. If it then would be placed at the origin as default, that would be even better.
  • rick_randall
    rick_randall Member Posts: 439 ✭✭✭
    I have a folder named " templates " that I have stored starter part studios just like you've described above - where you create blank parts set up how you like them, then later you copy workspace & move to your project (using them as templates) It is a workaround but is worth it (and is faster than creating from scratch).
     I also have one set up with 3 sketches with one construction line in each one, that defines x,y,z, axis ( this is a throwback to working in inventor ).
    The upshot is, if you think you'll use it a lot - make a your own template.
  • Thomas_Feix
    Thomas_Feix Member Posts: 2 ✭
    Adding to the conversation - I would like to define a plane in my assembly that is a symmetry plane. This way I can measure the distance between anything and the symmetry plane to get the overall dimension (I have only one side detailed out).
  • giacomo_ardesi
    giacomo_ardesi Member Posts: 13 ✭✭
    edited February 2025
    Planes in assemblies would be much needed! I can't believe this is not an option…at least there should be the option to be able to see visible planes of parts, in assemblies, so as to be able to use them to section views…c'mon!
  • MDesign
    I believe mate connectors are essentially your assembly planes
  • omna_tec
    omna_tec Member Posts: 3 PRO
    The mating process is fine, but there needs to be some way to address the sectioning, especially when you can't use a mate connector as a "plane".
  • romeograham
    Mate Connectors can be used to create a section view. Just select the Mate Connector, and the section plane will be defined by the XY plane of the Mate Connector.
  • adrian_vlzkz
    adrian_vlzkz Member Posts: 316 PRO
    edited May 2025
    Ultimately at the least the Section creation dialog should have an option to run thru the origin aligned with XYZ with angle control.
    This is the type of stuff that has our more advanced users not consider Onshape as a serious engineering tool
    CAD Engineering Manager
  • Amram_Chaim
    Amram_Chaim Member Posts: 2 ✭
    I think it’s very limiting having no planes in the assembly. I have rounded parts such as stacking cups,
    I couldn't section view about the front/side plane.
  • eric_pesty
    You should be able to pick any cylindrical or conical face for a section view, it creates the section along the axis of the face "snapping" to the nearest XYZ planes.
  • HARDWOODFP_ENGINEERING
    HARDWOODFP_ENGINEERING Member Posts: 42 PRO
    If you need planes visible or usable in an assembly, here’s a simple workaround I`ve tough about:
    1. Create a Part Studio with a flat surface.
    2. Insert that surface into your assembly and position it at the origin.
    3. Use that surface to create X, Y, and Z reference planes as needed.
    4. Save the assembly as a template so you can reuse it for future projects.
    If you want a part’s plane to be visible or referenced directly in an assembly, you can also create a surface in that part that coincides with the plane you want to use. Once inserted, that surface will be visible in the assembly where that part is inserted and can serve as a reference just like a plane.
    After some experimenting, I found that creating a part that’s essentially an extrusion of 0.00001 mm works better than using a surface. It behaves just like a plane but provides more mating options in assemblies.
