Can I derive a Part within the same Part Studio?
Ulises_FMUlises_FM Member Posts: 74 PRO
Im working withing a same PartStudio. I have several parts that share the same basic geometry. However, that geometry could be modify in the future so I want all the parts to be modify if any change is made to the initial geometry.
Derive does this, but I believe it works by linking a part from one Part Studio to other Part Studio. I didn't manage to make it work within the same Part Studio.
Am I missing something? Is there maybe an option in the transform feature that i could use instead?
Thanks!
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 481 PRO
    You can use the "transform" feature and choose "copy in place" as option.
  • rick_randallrick_randall Member Posts: 416 ✭✭✭
    edited May 2024 Answer ✓
    Or right click part in feature tree, choose "copy here" and it opens transform with "copy in place" already selected - ultimately the same thing, just another way to get there.
  • Ste_WilsonSte_Wilson Member Posts: 575 EDU
    You can use the 'use' command in a sketch to reference existing geometry which will then change with that geometry so a change in one place would cascade down your multi part part studio.
    Configurations?
  • Ulises_FMUlises_FM Member Posts: 74 PRO
    NeilCooke said:
    Configurations?
    Not quite. I mean, I want to create a bunch of parts that have some common geometry, and I would like them to be derived from the same master geometry. I guess I could create a MasterPartStudio and derive from there to another Part Studio but I was curious if it could be done within the same PartStudio.
  • john_lopez363john_lopez363 Member Posts: 140 ✭✭✭
    @javl0p_2 ... Sounds like a case for proper top-down, parametric modeling techniques...
    If you share a link, I'm sure multiple folks will chime in.
    Yes, I guess this is the correct way to go. I used transform by using mate connectors and It worked fine. Thx!
  • S1monS1mon Member Posts: 4,052 PRO
    There's a menu item and result I had completely missed. Nice.
