Having trouble selecting entities in sketch
mike_kelley685
Member Posts: 3 ✭
I am trying to follow the example in the help menu to create a spring. I am able to create a cylinder, and a helix. I then create a new point plane on the end of the helix. When I try to create a circle on the end of the helix, the pick point for the end of the helix will not light up. I was able to copy and past the circle to the end of the helix but when I go to revolve, I can select the circle but cannot select the helix for the path. Any ideas?
3dcad
Member, OS Professional, Mentor Posts: 2,476 PRO
Duplicate discussion with https://forum.onshape.com/discussion/2425/having-trouble-selecting-entities-in-sketch
@mike_kelley685 You can mark this discussion answered to keep things clear.//rami5
