Attractor Pattern junction
jean_philippe_delavalladejean_philippe_delavallade Member Posts: 14 ✭✭
Hi,
I'm trying the Attractor pattern on a solid of revolution. It's OK but the problem is that the pattern doesn't join correctly.
See the screenshot.
https://cad.onshape.com/documents/a5f5be574d6a5634babad56c/w/b224ed94db346ffded968616/e/3e37ea518e7fcf68281240a9
Thanks.
  • S1monS1mon Member Posts: 3,891 PRO
    @Evan_Reese
    I played with this a bit, and I can't easily tweak the parameters to solve the issue either. I suspect that I could hack it by dividing up the revolved bottle shape into a wedge and tweaking the angles until I could get something that would pattern nicely.
    I vaguely remember these kinds of challenges from using Attractor Pattern in the past. Perhaps the default should be to use the full parameter space with Border=0 even if the instances will only partially be on the surface. There could also be some sort of special accommodation for periodic surfaces.
  • jean_philippe_delavalladejean_philippe_delavallade Member Posts: 14 ✭✭
    "dividing up the revolved bottle shape into a wedge and tweaking the angles until I could get something that would pattern nicely"
    i've tried but the result is the same.
    Thanks
    edited June 2024
    @jean_philippe_de
    Here's what I meant.
    The trick is that I split the surface, and tweaked the 7.4 degree angle until the instances visually lined up with one 1/4 of the whole.
    Ideally this hack wouldn't be necessary. It would also be tricky to get this to be exact and parametric.
    Thanks !!
    and yes, this hack wouldn't be necessary.
  • EvanReeseEvanReese Member, Mentor Posts: 2,776 PRO
    This issue is on my backlog of things to fix with this feature, but I can't guarantee a timeframe for it. My priorities are elsewhere at the moment. What it needs is a way to tell when the base surface is periodic in the u or v direction, then update the grid accordingly.
    OK and thanks Evan.
