Constant plane via mate connector (FS)
ben_partouch
Member, csevp Posts: 168 PRO
Hello,
How do I establish a plane using a mate connector, in a way that no matter how I orient the part, the directions will remain the same.
The plane will be used for a sketch and then extrude the sketch normal to the sketch region.
Thank you
Thank you
Either:
- Construct a mate connector from selections in the feature. You need a point for the origin and two directions orthogonal to each other.
- Place a mate connector on the part being derived. If you move it after it is derived, you'd need to construct a query to transform the mate connector and the part.
Without explicit definition, you will be subjected to the right and left-handedness of edge direction (+Z direction) and implicit direction guesses when transformed in world space that will affect clocking (XY plane orientation about the Z).Support & QA0 -
The feature is creating new geometry in this case, so I assume opt 1 is preferable.
I can't figure out how to make a plane that is parallel to the Z normal direction. Only xy planes.
Thank you Jason.
would this work?
plane(coordsystem.origin, coordsystem.xAxis, yAxis(coordsystem));
//this would be normal to yaxis. swap the last two arguments to let the x axis be normal. either optionare parralel to Z.0 -
It's not clear what you are trying to do? I don't follow Jason's comments either.
If you just want to convert a MC to a plane, use evPlaneSenior Director, Technical Services, EMEA0 -
Thank you @jelte_steur814, I'll definitely try this.
@NeilCooke- Using evPlan with the MC only works in one orientation. As soon as the parts move the whole thing is messed up.
I want it constant and robust at all orientations.
How do I set a vector for a transform operation that is following the new coor' system?
So if I want to move 50mm only in the Y axis.
Thank you
i think something like this?
i didn't test any of this, but you get the gist I hope.
const direction = evAxis(yAxis).direction;
const translationVector = direction * (50 * millimeter);
It was close. Finally got it though.
Here's the solution:
var yDirection = yAxis(location2);var line1 = line(location1, yDirection);debug(context, line1, DebugColor.MAGENTA);const translationVector = yDirection * secRowDis;// debug(context, direction, DebugColor.RED);opPattern(context, id + "patternC", {"entities" : qCreatedBy(id + "boolean2", EntityType.FACE),"transforms" : [transform(translationVector)],"instanceNames" : ["secondraw"]0
