Use portion of an arc from an underlying sketch as part of a new sketch
frank_paynterfrank_paynter Member Posts: 32
In this document (Pill bottle cap V1 | Part Studio 1 (onshape.com)), I want to use a small portion of one of the circles that define the outer edges of my 'pill bottle cap' as part of a new sketch. I have played around with the 'Use' command, but haven't been able to make it work.  In my document, the 'Start of new sketch' sketch has just one line between two of the circles defining the rest of the cap.  I want to extend the line along the arc of the circles to the center line, and then use the 'Mirror' command to mirror this sketch to the other side of the centerline.
Any help would be appreciated
TIA,
Frank
    Looks like you deleted "Start of new sketch" - did you get it sorted?
