Hole did not regenerate properly
T3WIT3WI Member Posts: 5
Hello,
I am trying to add holes using the grey sketch in a part as seen below. I wanted to know why I am getting this error, as this has happened a few times already, and have gotten around it by just extruding circles. I've linked my part below, if needed.
Link to Part
Thank you!
  • james_aguilar160james_aguilar160 Member Posts: 46
    It is because of the fastener fit you've selected:
    • Fastener fit - Available only for Straight tap Tap type when 2 or more parts are selected in the Merge scope field. Select from None, Close, Free, Close (ASME), Normal (ASME), Loose (ASME).
  • robert_scott_jr_robert_scott_jr_ Member Posts: 485 ✭✭✭
    Try Up To Face as the termination. - Scotty
  • T3WIT3WI Member Posts: 5
    There is no Up To Face, only Up To Entity. Using that has the same error
