Mate Connector Z direction
kevin_aub
kevin_aub Member Posts: 5 ✭
Hi all.
I'm trying to use mate connectors to determine orientation. So in my case I want the wiring direction to be the Z axis of the MateConnector.
I've tried this so far:
    var cSys is CoordSystem = evMateConnector(context, {
            "mateConnector" : definition.startConnector
    var startOrigin = cSys.origin;
    var primaryAxis = cSys.zAxis;
    var plane = plane(startOrigin, perpendicularVector(primaryAxis));
    var sketch = newSketchOnPlane(context, id + name, {
            "sketchPlane" : plane
        skLineSegment(sketch, "line" ~ name, {
                    "start" : vector(0, 5) * millimeter,
                    "end" : vector(0, 0) * millimeter,
  • Caden_Armstrong
    You are setting your plane to only be perpendicular to the Z axis, but your plane needs to be such that the X axis is also set.
    plane(origin,zaxis,xaxis) will ensure that the plane is in a predictable direction so that you can have the X or Y axis of your sketch correspond to the Z direction.
    Another option you have is to use opFitSpline. If you only put two points into a fitspline it comes out as a straight line.
    That might get you your result more easily than creating a sketch just to create a line, as you can just put two 3d points in, such as your origin and origin+length*direction.
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    or just get the direction with this
    export function directionTo(fromPoint ,toPoint )
        return normalize(toPoint-fromPoint);
    If you need to make a line, this is by far the fastest method I have created below. The function accepts either 3d Vectors or a 3 dimension array of point values in meters. which is even faster.
    function opLine(context is Context, id is Id, startPoint, endPoint)
             @opCreateBSplineCurve(context, id, {
                    "bSplineCurve" : { "controlPoints" : [startPoint, endPoint], "degree" : 1, "dimension" : 3, "knots" : [0, 0, 1, 1], "isPeriodic" : false, "isRational" : false }
    sorry for the formatting above.
  • kevin_aub
    Thanks @Caden_Armstrong and @Jacob_Corder. Your guidance greatly helped expand my understanding and I managed to do what I needed from this. Since I wanted to use the positive Z direction of the Mate Connector I had to play a bit with fromWorld but I think I got there eventually!
