Extrude problem
bill_green836bill_green836 Member Posts: 2
I am having a problem when extrude a sketch.   When the extrude window is open and I select new it adds a part but when I hit the green check the original part disappears? Can anyone help with this?
After I hit green check mark.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,681
    In the Boolean feature at the end you need to select Keep tools.
    Senior Director, Technical Services, EMEAI
