Circular pattern failing without any message
nicholas_betts
Member Posts: 2 EDU
In this part studio for a worm gear the main gear fails to generate properly when the Z1 parameter is changed to 2. The problem occurs in the Circular pattern 2 feature. The pattern should replicate the grove 20 times, but every second one fails. While editing the feature it looks as shown in this image. The red outline suggests some error like non-manifold geometry, but there is no message about it and the feature is not showing as red. I have made a copy of my own and tried to correct the problem, but have not had any luck. I have two questions.
P.S. First time posting. I hope this question is appropriate and makes sense!
- Why is no error displayed?
- Is there some way to fix the problem and generate the gear properly.
I have made a copy of the document here. This is not my original copy because that is full of crazy experimentation to try and fix it (which I did not do properly with a branch).
https://cad.onshape.com/documents/658914e59bb2713d1e9de226/w/434e6075bee64f11dd317ef9/e/095b7c1abdc18908065ac478?configuration=B=0.0045000000000000005+meter;Module=5.0E-4+meter;Q=10.0;X=0.0;Z1=2.0;Z2=20.0&renderMode=0&uiState=6690eca4d7b1af22aba457d6
