Linear Sketch Patterns causing very high regeneration times
Edgar_aspLED
Member Posts: 4 PRO
Hello all,
The majority of my designs in Onshape are for designing toolpaths for a CNC mill. The patterns we're making are very tightly spaced lines, all approx 5mm apart, with the final patterns almost looking like graph paper and then exported as a DXF for our CAM software. For smaller patterns it doesn't seem to cause too many issues, but if we have to do a pattern that is meant for a larger product (like 5-7 feet long and 2-3.5 feet wide), it's taking Onshape very long times to regenerate, even sometimes completely freezing and spitting out error support codes. Is there a less intensive way to get this type of pattern without causing the high regeneration times? I don't ever need to extrude or make multiple parts so I'm only using various sketch layers for certain aspects, then using the Use option to project all the sketches to a single sketch which I then export out to DXF.
I've attached an example of a finished toolpath pattern which is 12 x 12 inches.
NeilCooke
Moderator, Onshape Employees Posts: 6,041
You'd have to insert it into a drawing and export from there. But the feature would also need to be modified to include the tool motion at the ends.Senior Director, Technical Services, EMEA0
