How do I pick an entire face
ron_morelandron_moreland Member Posts: 90 ✭✭
I'm trying to loft a simple rectangle. It's outlined another drawing made of 3 other shapes. To loft, I want the rectangle, but I keep getting the outlines of the other shapes. In the image the yellow outline is the shape I'm getting. It's not part of the sketch with the grey rectangle. Loft will not let me pick the rectangle. It's very frustrating.
  • ron_morelandron_moreland Member Posts: 90 ✭✭
    I'm going to answer my own question:
    I can pick the components in as entities in one profile. I thought that was the solution, but I couldn't figure out how to do it. I just did.
  • Oliver_CouchOliver_Couch Member Posts: 179 PRO
    You want to enable the "Disable imprinting" option in your sketch. Or you can just select the several different sections that combine to makeup the rectangle.
