Creating materials while we work
martin_kopplow
Member Posts: 1,306 PRO
Yepp, I want to calculate their mass and maybe run a simulation on them later. But as the help file already states: I have to input all the custom values for all the parts manually time and again (or create a new material library). Is it only me, or is that a generally pretty tedious method to handle this? I feel there should be at least a "Copy Material" option for when I need the german material name, so I could just copy an existing material and assign the correct name, and there should be an "Add to custom library" button so I can create a new material as I work and then re-use these material for other parts. The material library that comes with OS is just not as comprehensive and not as multilingual as to ignore this requirement.
-I maintain a spread sheet that was generated by OS, the headers can not be changed, it's strictly bound, don't change them.
-I add new materials to the sheet
-then I update the material library with a csv from spread sheet
-oh yeah don't forget to version the material library
Oddly it's not that bad but wish it was easier like what you're showing, I voted it up.
When adding numbers, use 34e6 for mega & 34e9 for giga stuff, don't use zeros, it's too hard to maintain the zeros.
If you're working with printed materials, wood, water, granite and a lot of other things in the real world, then you should have your own material library.
If you publish more than one material library in your Enterprise (or Professional Company, I expect) you have a drop-down option for which library you want to use. You can mix and match the libraries used in a document or tab. I rarely add materials so I when I need to add / edit a material, I export the library from Onshape each time, edit it, re-upload, and Version the document.
