Moving a modeled part?
jack_erhartjack_erhart Member Posts: 140 ✭✭
Besides mate connectors, is there a method for moving a part to a face, or to a vertex like in an extrusion?
  • S1monS1mon Member Posts: 4,062 PRO
    Moving in a part studio or an assembly? In either case, there's a transform tool, but perhaps you can be more specific about what you're trying to accomplish.
  • jack_erhartjack_erhart Member Posts: 140 ✭✭
    Thank you S1mon. I'm working in a part studio, and when moving exsisting parts around, I thought that if I could maintain the direction (axis) I am moving the part but have the move terminate at a give point or face would be very helpful. I can do that with a extrusion, but not with a completed seperate part.
    Can that be accomplished?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,611 PRO
    @jack_erhart
    You might be able to use the "Transform by line" option. It require creating a line first corresponding to the transform distance and direction. You could use either a sketch or a "3D fit spline" between two points in 3D (or a combination of both).
    You can also edit the mate connectors to keep the alignment the same when doing a transform by mate connectors.
