My sheet metal parts won’t sheet metal
nolan_kiefer427
Member Posts: 5 PRO
I’m trying to make a sheet metal part, and nothing is working. It was a sheet metal part, then I turned it into a part, now I’m trying to turn it back into a sheet metal part. After I select all the flat faces, then select the edges or cylinders to bend it makes them there own parts, like in the last picture. If I select all the faces, including bends, and press include bends, it deletes the part. I don’t know what I’m doing wrong. Thanks in advance!
The 'Faces or sketch regions to thicken' selection needs to have the cylinders selected there too.
IR for AS/NZS 1100
I tried that and it still says “Selected cylinder cannot be used as a bend”
