My sheet metal parts won’t sheet metal
I’m trying to make a sheet metal part, and nothing is working. It was a sheet metal part, then I turned it into a part, now I’m trying to turn it back into a sheet metal part. After I select all the flat faces, then select the edges or cylinders to bend it makes them there own parts, like in the last picture. If I select all the faces, including bends, and press include bends, it deletes the part. I don’t know what I’m doing wrong. Thanks in advance!
