How to limit rib length
amir_livne
amir_livne Member Posts: 85 ✭✭
Hi
Is there any way to limit Rib length
Attached picture
Thanks
Amir Livneh
    S1mon Member Posts: 4,613 PRO
    It’s probably easier to just use an extrusion instead of a rib in that case.
  • amir_livne
    Thank you, but I cannot accept it
    Why?
  • amir_livne
  • amir_livne
    In that particular case it may give an answer but in case of cylindrical part it will be a problem.
    More then that - as a teacher I'm teaching my students to use the right feature in the right place and here we have a problem.
  • glen_dewsbury
    You can fix this by changing the sequence, however you my want to report this as a bug to avoid having to go back and fix problems.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,930 PRO
    You could also add a split face and delete face after the fact…
    Not ideal but dealing with unexpected results/limitations should also be part of teaching (and that's a good workflow to know anyway)!
  • amir_livne
    Hi
    I found a way to cope with that problem/
    I just move the rib before the cone
