Perpendicular Vector
graham_lock
graham_lock Member Posts: 277 PRO
Hi
I'm drawing a sketch line on a plane which has its own coordinate system:
const lineEndPoints is map = skLineSegment(sketch1, "line1", {
"start" : vector(0, 0) * meter,
"end" : worldToPlane(sketchPlane, vector(dist.sides[0].point[0] / meter, 0, dist.sides[0].point[2] / meter) * meter) // point[0] is x, point[2] is y
I then need to draw a rectangle of a given size which has 2 edges perpendicular to that line, positioned at one endpoint, similar to:
I've been experimenting with perpendicularVector but haven't found how to make it work.
If this is the correct approach a quick example of its use in this use case would be greatly appreciated.
If this is not the correct approach how should I go about it?
Thank you.
    edited October 2024 Answer ✓
    perpendicularVector is for 3D vectors and there's no guarantee that it will be on your sketch plane.
    Best to do all the vector math outside of the sketch, draw the rectangle at the origin then transform it.
    FeatureScript 2473;
    import(path : "onshape/std/common.fs", version : "2473.0");
    annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "X" }
            isLength(definition.dx, LENGTH_BOUNDS);
            annotation { "Name" : "Y" }
            isLength(definition.dy, LENGTH_BOUNDS);
            const lineStart = vector(0, 0) * millimeter;
            const lineEnd = vector(definition.dx, definition.dy);
            const lineLength = norm(lineEnd - lineStart);
            const lineAngle = (definition.dy < 0 ? -1 : 1) * acos((lineEnd[0] - lineStart[0]) / lineLength);
            const angleTransform = matrix([[cos(lineAngle), -sin(lineAngle)], [sin(lineAngle), cos(lineAngle)]]);
            const boxWidth = 2 * millimeter;
            const boxHeight = 1 * millimeter;
            var rectangle = [vector(boxHeight, boxWidth), vector(-boxHeight, boxWidth), vector(-boxHeight, -boxWidth), vector(boxHeight, -boxWidth), vector(boxHeight, boxWidth)];
            for (var i = 0; i < size(rectangle); i += 1)
                rectangle[i][0] += lineLength;
                rectangle[i] = angleTransform * rectangle[i];
            const sketch1 = newSketchOnPlane(context, id + "sketch1", {
                        "sketchPlane" : XY_PLANE
                        "start" : lineStart,
                        "end" : lineEnd
            skPolyline(sketch1, "polyline1", {
                        "points" : rectangle
            skSolve(sketch1);
    FeatureScript 2473;
        precondition
                        "end" : lineEnd
            skSolve(sketch1);
  • graham_lock
    Thank you so much for the example - exactly what I was looking for.
  • graham_lock
    @NeilCooke
    Hi @NeilCooke,
    I've integrated your example into a test document and it does exactly what I asked for, the box profile follows the edge of the curved face and is perpendicular to the line.
    Could you suggest the best way to make the profile follow the line as currently but be oriented such that it is tangent to the curved edge please?
    https://cad.onshape.com/documents/5ae9b4531272e0d2f135073c/w/bc3f6ab2b17a961efef1b4fd/e/14315dad3efc51b9f4fe8227
    Thank you.
  • graham_lock
    edited October 2024
    Thank you - that's very clean.
  • graham_lock
    edited October 2024
    Hi,
    I inadvertently marked the original question as answered and couldn't see how to unmark it - is there a way?
    To continue with the help provided by @NeilCooke …
    I've created a test document which allows switching between tangential and perpendicular tracking.
    This has generated another question:
    1. Tangential tracking works fine if the curved edge is generated via a spline but if generated via an arc the profile is drawn outboard of the edge. This can be corrected by changing
    line 126:
    boxPlane = plane(edgeTangentLine.origin, -Y_DIRECTION, edgeTangentLine.direction);
    to
    boxPlane = plane(edgeTangentLine.origin, Y_DIRECTION, edgeTangentLine.direction);
    but then spline generated curves are incorrectly calculated?
    https://cad.onshape.com/documents/a210980f37f6eb8934643f1d/w/c438d98168a82355ea5d0764/e/f4d243419a7ec6ec132347ac
    Any further help appreciated.
    Thank you.
