Why some expression couldn’t be resolved shown ?
dhrumit_chudasama
Member Posts: 7 ✭
I am working on one project in which I integrate the python code with onshape design in which python code ask user input like diameter and length and modify this data in main design,code is running properly but when I open the design in onshape after code run the design is disappear and error shown like :”some expressions couldn’t be resolved “….
GregBrown
Member, Onshape Employees, csevp, pcbaevp Posts: 381
We might need to see something, perhaps a public link to a doc, otherwise it will be hard to help out…
2
Link:https://cad.onshape.com/documents/f571272c2d5777190eec3357/w/1b439b876ebef66aec785f6e/e/9dc3f351f58456587c78fdea
1st image of onshape design before code run
2nd code successfully run
3rd onshape design after code run(design is disappear)
Two things - I don't see that endpoint in Glassworks? Can you send a link to it? Secondly, it is likely that you are just sending a number rather than a ValueWithUnits which is required.
you mean in code, I add this link as base url:https://cad.onshape.com/api/partstudios/d/f571272c2d5777190eec3357/w/1b439b876ebef66aec785f6e/e/9dc3f351f58456587c78fdea/configuration.
And I also put the value of input dia and length with unit but it doesn’t work !
I also give the main link of document if you know which link I put in my code to modify the dimensions,you give me that link …
