View Dimensions
gerald_friedmangerald_friedman OS Professional Posts: 50 ✭✭
When I as to View Dimensions of a feature (extrusion) all I get is the sketch dimension, not the extrusion length.
Am I missing something?
  • shashank_aaryashashank_aarya Member Posts: 265 ✭✭✭
    Yes, you are correct. At this point of time only sketch dimensions are shown but I guess provision of showing the extrusion length is also one of the improvement from the Onshape's list of priorities.
    @gerald_friedman
    Are you after screenshots with dimension or just wan't to know some measure/distance?
    I have asked for advanced 'named views' with possibility to add visible dimension since I would need to share these images. But if you just wan't to check some dimension, click any edge and see the measure in bottom right - click another instance and you will get distance and other measurement info.
    //rami
  • gerald_friedmangerald_friedman OS Professional Posts: 50 ✭✭
    Gentlemen,
    When asking to show dimensions one also has the opportunity to select a dimension and revise it, although when selecting the dimension you are brought back to the sketch and have to re-select the dimension to revise.
    Without being able to see the extrusion dimension I have to go back to the extrusion in the feature list to bring up the dialogue box.
    I feel this is a bit cumbersome.
    I'd rather be able to revise on the model. Would be much quicker.
