Fillets on internal corners
graham_lock
graham_lock Member Posts: 277 PRO
Hi,
I have bodies which look like this:
I'm trying to workout how to find the internal corner edges so I can apply fillets?
I'm using qSmallest(qOwnedByBody(body, EntityType.EDGE)) (is there a better way?) which returns all 8 corner edges but how should I filter the inner ones?
Any help appreciated.
Thank you.
    S1mon Member Posts: 4,646 PRO
    You could look at the code for selection fillet, or just use the custom feature.
  • lana
    You can use evEdgeConvexity for the edges, You are interested in concave edges.
  • graham_lock
    Thank you for your reply.
    I now have the following:
    for (var edge in evaluateQuery(context, qSmallest(qOwnedByBody(outerSplitBody, EntityType.EDGE))))
    if (evEdgeConvexity(context, {
    "edge" : edge}) == EdgeConvexityType.CONCAVE)
    debug(context, edge);
    println("Found internal edge");
    This does indeed find the internal edges - is this your intended approach?
  • graham_lock
    Thanks @S1mon i’ll take a look at that.
  • lana
    @graham_lock
    Yes - that looks correct.
