Coincident constraint leaves gap between splines
nn_e
nn_e Member Posts: 2 EDU
Im trying to make a face closing the path between the inner ear spline and the body spline, but the point will not lock onto the line whether I constrain it or not. Dont mind the copied part studio, that was just a testbed that got me nowhere.
image.png Screenshot 2024-11-19 at 8.48.55 PM.png Screenshot 2024-11-19 at 8.49.07 PM.png
  • rick_randall
    rick_randall Member Posts: 437 ✭✭✭
    edited November 2024
    @nn_e - As a test, see if you can extrude the inner profile area - If it extrudes you know the endpoint is constrained correctly. I suspect that it actually is constrained, but just appears not to be on the viewing screen because of line tessellation (this appears to get worse the tighter you zoom in). It's just the normal way the graphics are rendered on your screen. In time you'll learn to ignore it.
    Edit - The blue dot on the last screenshot is the point's true location - and if constrained the black line does go through that location, in reality (just a rendering glitch on the screen)
