Is there a way to change default part colours? (Blue, then gray, then dark blue, etc.)
skelobonesskelobones Member Posts: 25 EDU
Wondering if there is a way to change the default part colours that automatically form when you make a part.
  • skelobonesskelobones Member Posts: 25 EDU
    I also noticed they are at the top of the palette. Are they 'favourited' or something similar?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,087 PRO
    It goes in order from left to right of the top row with every new part made. Repeats when it gets to the end.
  • rick_randallrick_randall Member Posts: 416 ✭✭✭
    edited November 2024
    Right click on part in the feature tree - then select "edit appearance" then click on your choice in the palette. But I don't think there is a way to change the preset default color routine.
    Others can correct me if I'm wrong.
    Colour cycle is hard coded.
  • MDesignMDesign Member Posts: 1,332 PRO
    So for the non techie that's a hard NO to the original question. 😃
  • anton_stevanovic897anton_stevanovic897 Member Posts: 1
    edited March 2025
    I would love to see you implement functionality for choosing a custom default color palette/order!
  • Severin_123Severin_123 Member Posts: 47 PRO
    would also like to see that as an improvement (+1)
