POST /elements/copyelement/{did}/workspace/{wid} return Bad Request
I want to copy an element from another workspace to my workspace. The API code I called is as follows, but it returns 400 Bad Request. Why can't I copy it?
  def copyElement(self, source_url, target_url):
v_list = source_url.split("/")
sdid, swid, seid = v_list[-5], v_list[-3], v_list[-1]
v_list = target_url.split("/")
tdid, twid, _ = v_list[-5], v_list[-3], v_list[-1]
body = {
"documentIdSource": sdid,
"workspaceIdSource": swid,
"elementIdSource": seid,
"isGroupAnchor": True
res = self._api.request("post", "/api/v10/elements" +
"/copyelement/" + tdid +
"/workspace/" + twid,
body=body)
self.to_jsonfile(res.json(), "copyElement") source_url = "https://cad.onshape.com/documents/56fb9fbbe4b01bbb565f8527/w/c64129b1ffea6a9dce644def/e/19e777a0e100efd7c473ef8d"
target_url = {my_workspace_url}
  • chadstoltzfus
    chadstoltzfus Member, Developers, csevp Posts: 175 PRO
    Intersting, I kept getting a "Bad request" which tells me something else is going on. I created a copy of the workspace and tried just manually copying and pasting the element and got the following
    So there might be something wrong with the Part Studio itself. Upon looking at the FeatureScript for that Part Studio (right click on the part studio > Show code) I can see that the FS version is really out of date so that might have something to do with it.
    Try deleting the document, then restoring it from the trash, then going into it should prompt you to update the version of the standard library. Doing that fixed it for me.
    chadstoltzfus@premiercb.com
  • Paul_J_Premakumar
    Paul_J_Premakumar Member, Onshape Employees Posts: 238 image
    A couple of debugging tips:
    1. Print out the URL request & verify it looks correct.
    2. Try this from glassworks https://cad.onshape.com/glassworks/explorer#/Element/copyElementFromSourceDocument and see if you are getting the same error. . If it works in glassworks, the issue is likely with the code snippet & how it is setting up the params. If it errors in Glassworks took, the problem is with the inputs.
  • jiahao_lee103
    jiahao_lee103 Member Posts: 14 EDU
    Thanks for you response @Paul_J_Premakumar , I tried glassworks https://cad.onshape.com/glassworks/explorer#/Element/copyElementFromSourceDocument but it still not working with same error:
    "message" : "Bad Request.",
    "code" : 0,
    "status" : 400,
    "moreInfoUrl" : ""
    I also double checked the paramters and ensure it's correct.
    The request information in glassworks is as follows:
    Curl
    curl -X 'POST' \
    'https://cad.onshape.com/api/v10/elements/copyelement/d4bb557fa5816180433be149/workspace/6c6e57defeb8a10626967208' \
    -H 'accept: application/json;charset=UTF-8; qs=0.09' \
    -H 'Content-Type: application/json;charset=UTF-8; qs=0.09' \
    -H 'X-XSRF-TOKEN: {my_onshape_token}' \
    -d '{
    "documentIdSource": "56fb9fbbe4b01bbb565f8527",
    "workspaceIdSource": "c64129b1ffea6a9dce644def",
    "elementIdSource": "19e777a0e100efd7c473ef8d",
    "isGroupAnchor": true
    Request URL
    and the source element: https://cad.onshape.com/documents/56fb9fbbe4b01bbb565f8527/w/c64129b1ffea6a9dce644def/e/19e777a0e100efd7c473ef8d is public you can check it out.
    The target document id did and workspace id wid in Request URL is from the document I newly created.
  • Paul_J_Premakumar
    I am able to reproduce the issue. Can you copy the document from the Onshape UI and see if it works for you? If you are blocked, please open a support ticket.
  • jiahao_lee103
    Thanks for your help. Copying in Onshape UI works(but the copying in UI is done by copying the entire document, not just a single element)
    So it seems to be a problem with the API itself? Will you consider fixing it later?
  • jiahao_lee103
    Now if I want to copy an element via API, is the only way to do this by copying the document?
    The only source information I have now is the URL like: https://cad.onshape.com/documents/56fb9fbbe4b01bbb565f8527/w/c64129b1ffea6a9dce644def/e/19e777a0e100efd7c473ef8d
    But I don’t quite understand the parameters in copy document method: https://cad.onshape.com/glassworks/explorer#/Document/copyWorkspace
    1. Is the parameter in the URL source or target? POST /documents/{did}/workspaces/{wid}/copy
    2. How to obtain the parameters in the Body {
      "isPublic": true,
      "newName": "string",
      "ownerId": "string",
      "ownerTypeIndex": 0,
      "parentId": "string",
      "projectId": "string"
      } (Based on I only have the onshape URL)
  • chadstoltzfus
    @jiahao_lee103 I've been using the copyElement endpoint.
    Body params are:
    'body' : {
    'anchorElementId' : "string",
    'documentIdSource' : "string",
    "elementIdSource" : "string",
    "isGroupAnchor" : boolean,
    "workspaceIdSource" : "string"
  • jiahao_lee103
    edited December 2024
    Hi, @chadstoltzfus
    Did you copy this public element ("https://cad.onshape.com/documents/56fb9fbbe4b01bbb565f8527/w/c64129b1ffea6a9dce644def/e/19e777a0e100efd7c473ef8d")?
    I tried again and it failed. Can you give me your detailed parameter values? Thank you very much.
  • chadstoltzfus
