Laser joint got funny?
ricardo_raimondo
Member Posts: 66 ✭✭
Until some time ago the laser joint was a beauty and very important feature for my projects, however, today I tried a simple joint and then was when it got funny. Anyone can tell me what it is wrong with this? May be I missed an update?
Here is the link to the doc
And here is what I get
I tested your setup with older versions of the feature with similar issues. I think it's something about how your parts are designed. The "Steering Servo tray" (light blue in your image) isn't a flat laser-cuttable sheet, which could be throwing it off.
I
I think you are right. In the same document, I just created two walls of a box and the LJ works as expected I will review the design of the part you suggested. I'm pretty sure the problem is there.
Confirmed. The part design was the problem. Problem solved.
