Laser joint got funny?
ricardo_raimondoricardo_raimondo Member Posts: 60 ✭✭
Until some time ago the laser joint was a beauty and very important feature for my projects, however, today I tried a simple joint and then was when it got funny. Anyone can tell me what it is wrong with this? May be I missed an update?
Here is the link to the doc
https://cad.onshape.com/documents/2abe22b1712ef9125714faff/w/c6816f37cb70b4beeb13d096/e/146ba54b71aa1d337cef9b52?renderMode=0&uiState=6758749a4339477338756308
And here is what I get
  • EvanReeseEvanReese Member, Mentor Posts: 2,456 ✭✭✭✭✭
    I tested your setup with older versions of the feature with similar issues. I think it's something about how your parts are designed. The "Steering Servo tray" (light blue in your image) isn't a flat laser-cuttable sheet, which could be throwing it off.
  • ricardo_raimondoricardo_raimondo Member Posts: 60 ✭✭
    I
    I think you are right. In the same document, I just created two walls of a box and the LJ works as expected I will review the design of the part you suggested. I'm pretty sure the problem is there.
    Confirmed. The part design was the problem. Problem solved.
